![]() Slow progress, but I shortened the pickup pipe and have an oil return and drain plug. Whoohoo.
![]() Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
![]() You can't rush perfection
![]() Russ |
![]() I was actually thinking, If you were not extending the sump backwards, you could drill and tap the 6 bolt posts from the bottom and bolt on a 5-6mm piece of aluminium or some steel with sealant gasket rather than needing to get it all TIGed up.
![]() I wasnt going to extend back but decided I would... Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 Last edited by Stot : 4th November 2014 at 10:26 PM. |
![]() Im swapping to 13" wheels and tyres as I want to get a softer compound tyre and have the extra sidewall flex so bought 1 just to make sure it cleared everywhere ok.
![]() ![]() ![]() They clear the 1.6 running gear nicely so ordered the other 3. Ill cover them in A021Rs in 185/70/13 from http://www.polleymotorsport.co.uk/ only £50 each + VAT. Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 Last edited by Stot : 4th November 2014 at 11:28 AM. |
![]() Got my downpipe sorted today. Made a frame from exhaust brackets and 20mm tube then cut and welded bends n flanges.
I have an O2 bung to go on the lower section and its done. Cheers Stot
![]() That fit quite well.
![]() ![]() ![]() Cheers Stot
![]() Well done, looks good. Nice winter project that. Will you wait for spring before you drive it in anger?
![]() Quote:
Thanks |
![]() Quote:
The guy that welded mine up hated it and said never again. Cheers Stot
