Old 1st April 2013, 12:38 AM
thailoz thailoz is offline
Default Build table
Ok its time to stop lurking and get on with it .
I will be getting the materials for my build table this week....15 mm ply for the top and 2x2 for a frame
what should I use for legs and how tall have you guys found to be a good height ?
To be honest this is the bit ive been dreading I am crap at woodwork ,
Old 1st April 2013, 12:53 AM
Easiest thing i found was a couple of wooden saw horses.Also at a good height then.
Old 1st April 2013, 12:43 PM
2x2 sounds a bit underengineered, that will definitely bend under the weight of the chassis. You could attach another sheet to the bottom to strengthen it. I used 2x4s and they've bent a bit with time.
Here's how I did the feet:
Old 1st April 2013, 01:55 PM
will_08 will_08 is offline
Albert could you build me a snooker table?
