Old 23rd April 2013, 10:47 AM
Default IVA Covers for track rod end and drag link?
Any ideas what I can use to IVA-proof the top ball joints and track rod ends?
Ta,
Old 23rd April 2013, 11:31 AM
will_08 will_08 is offline
Might be off at a tangent here, but i think ive seen people using the shroud's of steel wire armoured glands on locostbuillders?
Old 23rd April 2013, 12:43 PM
Ta,
for the top ball joints ive seen a large nut cover split with the rounded end removed. This is how they did it on the westfield from a race car is born. For the track rod ends you could use large heatshrink??
Old 23rd April 2013, 01:29 PM
gland covers from SWA cable glands work great and look spot on
if your lazy you can buy them from kitspares http://www.kitspares.co.uk/shop/item.php?product=5093
thay are a little longer than some of the gland covers i have seen and the track rod one you can cut the large end off to use for the outer nut so both are coverd
Old 24th April 2013, 11:13 AM
Perfect
Thanks all!
