Old 24th April 2013, 11:15 AM
MikeB MikeB is offline
Default Help - Where is it! The Engine Number on a CVH
I've been looking for it to no avail.
All i can think is its hiding under the timing belt covers somewhere.
I have the number as it forms part of the donor chassis number (the last 7 digits) but I can't find it on the engine and mr IVA will need to see it!!
Old 24th April 2013, 12:21 PM
remind me tonight and I will have a look at the official technical manual for the 1.8CVH.
Old 24th April 2013, 12:49 PM
good man thanks!
Old 24th April 2013, 02:14 PM
Look on the inlet side to the left or right of manifold on a protruding piece of the block
Old 24th April 2013, 02:54 PM
you wouldn't happen to have a picture?
Is it towards the front or rear of the engine, on the block not the head and fairly high up.
I've moved my alternator to the inlet side so wonder if I've covered it up if its low down.
Old 24th April 2013, 04:51 PM
Mine is near the front high up on the block but it could be at the rear too!
Old 24th April 2013, 05:55 PM
Here you go
Old 25th April 2013, 10:08 AM
twin = legend!
Right will have to whip off the alternator at IVA or do you think he'd take a photo, it a pita as the belt I'm using doesn't quite give enough slack to get it off, so I have to unbolt the alternator mount that is connected to the engine mount
