![]() I should be ready to fit these by the weekend but the book says they have a 5 degree angle which way does this angle need to be .I can't for the life of me work it out
![]() On another not the dreaded Front frame Is it advisable to weld it fully before fitting?
My build diary is at http://thailoz.wordpress.com/ Last edited by thailoz : 10th May 2013 at 01:02 AM. |
![]() Quote:
They're not perpendicular to the bottom rails! ![]() |
![]() Quote:
![]() As for the front frame I am not sure what you mean sorry
My build diary is at http://thailoz.wordpress.com/ |
![]() [quote=Talonmotorsport; If you make the front frame the same as the book with the pie cuts and bends your top wishbone brackets will need packing out and the brackets will not sit square on the tube.[/QUOTE]
Ah yes! I remember it well ![]() |
Thread Tools | |
Display Modes | |
