Old 1st September 2013, 04:11 PM
BenBrooks BenBrooks is offline
Default radiator mount help
Hi all, I've just made my radiator mounts and then started to worry if it was a bit too tall and whether it would fit under the nose cone. It stands approx 150mm taller than the top of the front frame and 150mm forward of the front edge of the top of the front frame. can anyone who has a nose cone on and who has a spare 5 minutes tell me if i need to change these mounts?
thanks
Ben
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 1st September 2013, 04:41 PM
Hi Ben just been out and checked mine and the radiator is sitting 80 mm to the outside of the radiator and 130mm to the uppermost part of the radiator (ref the top of the frame) and there is a good 30mm up to the nosecone and heaps in front of like 150mm at the top and 100mm at the bottom and I have used the VW polo radiator
Old 1st September 2013, 05:07 PM
thanks for that, i'm using a polo radiator too so I'll leave it for now then might change it when i get a nose cone but it sounds like it'll fit fine.
(just trying to mount the tank you made, it looks the business i'm very happy with it)
