Old 7th October 2013, 12:59 PM
Default Two 7" 3.62 Sierra diffs
Both are 7" 3.62 ratio open diffs for push in shafts.
The first is to suit the larger splined type of push in shafts (28 splines, 30mm diameter end).
I got this from Gavin174 on locost builders as a good useable diff and got as far as draining and cleaning it before I realised there ARE 2 different sizes of push in shaft.
£ 50
The other diff takes the smaller push in shafts (22? splines, 25mm diameter ends)
This is my old diff which runs but whines and has some play in the pinion. That said it's by no means the noisiest diff ive heard but is more noticeable at speed and tended to get on my nerves during long journeys.
Ideal for parts or to rebuild or indeed just for urban/ track use, if you dont mind a bit of noise.
£ 25
Collection from Southend or happy to package and arrange courier at cost.
Not sure if it's of interest but ive somehow ended up with an old but complete windscreen assembly from a Robin Hood S7. It's a fairly wide screen that was made for a flatter type of scuttle than the Haynes but might be of some use to someone.
£ 20
