Old 21st February 2014, 10:17 PM
Default Chassis Plate
I have just made up my chassis plate and attached it to my bulkhead under the bonnet. From reading the iva manual it looks like I can get away with just including the vin number and the manufacturers name.
My question is... Am I the manufacturer ie David bolam or do I put haynes roadster or saturn roadster?
If I put the manufacturer as David bolam will this show on the v5 as a DavidBolam roadster or a haynes / Saturn roadster???
I'm confused as I haven't got the forms to register for an iva etc yet.
I know skov put skov on the chassis plate but will it be officially a skov roadster?
Thanks
Old 22nd February 2014, 12:46 AM
Hi Dave ....I just put my name next to manufacturer, it also has the advantage of being able to change design specs if you have to. (Axle weights in my case)
Old 22nd February 2014, 08:07 AM
Yes, unless they've changed the manual since I had my IVA all you need is manufactuer and VIN number.
Manufacturer can be anything you like, within reason (the DVLA won't be impressed if you use anything offensive!).
I think it's usual to use either Haynes, your name, or your nickname.
I put the manufacturer down as 'Skov', and the model as 'Haynes Roadster'.
Don't know why, but the model ended up being blank on my V5, so as far as the DVLA are concerned it's just a Skov.
Old 22nd February 2014, 08:03 PM
Bolam Engineering !
Old 22nd February 2014, 11:42 PM
Originally Posted by flyerncle View Post
Bolam Engineering !
I might go for bolam eng.... I will never get engineering stamped without getting one of the letters back to front!
Thanks for all the pointers chaps
Old 23rd February 2014, 08:53 AM
Draw it on with a pencil first.
