Old 29th March 2014, 05:09 PM
Numplumb Numplumb is offline
Default Steering column thickness
Hi all what wall thickness are you guys using for steering shaft (MX5 build)?
I have some gas barrel which has the exact ID for the MX5 shaft.
Which has a wall thickness of 3mm would that be okay.
Regards Mick.
Old 29th March 2014, 05:41 PM
I would say 3 mm is more then enough I'm using 2.6 on my mx5 build!
The only thing I would say is weld and roll pin the shaft!
Build pictures
