Old 26th June 2014, 03:13 PM
Default Weight
I'm just about to fill in my IVA form but not sure what weights shall I put down on my IVA form?
what has anyone else done for this?
Old 26th June 2014, 03:27 PM
Peter-C Peter-C is offline
I put down 450 kg, 450 kg and 900 kg gross. This is the same as on my manufactures plate. The examiner said that was ok.
Old 26th June 2014, 03:41 PM
yep they are the numbers I used.... BUT the way I built mine sent my rear axle weight over but being the manufacturer you can just write it down on a piece of paper informing them /him of a specification change
Old 26th June 2014, 04:14 PM
Thanks for the replies
I will fill out the forms hopefully this weekend
Old 26th June 2014, 04:29 PM
I did the same. My MX5 build is weighing in at ~620kg without fuel so if there is more than 450 over the back something is up!
Old 26th June 2014, 08:24 PM
i put the same as thats in the book and i pased fine even with a 35l fuel tank
axle 1=450kg
axle 2=450kg
total = 900kg
Old 27th June 2014, 08:21 AM
It does not make sense the weights being the same,if you put both axles at the same weight then the DGW is say 900 kg one axle would possibly be overloaded ie the front one.
Old 27th June 2014, 01:39 PM
450 / 450 / 900 worked for me.
Old 28th June 2014, 06:42 PM
After thinking about it,its probably good numbers and maybe a little high for the rear.
Old 30th June 2014, 07:48 AM
snapper snapper is offline
The axle weights are the max fully loaded that the car is designed to take not the actual as measured
Weights include full fuel tank 25 to 35Kg
Driver and passenger 75Kg each
Luggage 25Kg each
Design weights for IVA are used to find if the build is within design limits and also to work out the brake bias when tested on the brake rollers
As axle weights are measured on the rollers and one axle is on the hard standing there is a slight lever effect
