Old 17th November 2014, 07:30 PM
Rosco Rosco is offline
Default Rear upright holes x 2
Right, I've done a seach and found a few similar threads but not really found an answer for both of my problems
Problem 1
I have made the rear upright as in the book with the tube for the rear wishbone bolt 62mm up from the jig, then once I was ready to tack the rear upright I double checked the hole for the shock as in fig 5.24, it says 66mm but it is 70mm and 70mm back works correct to the 62mm if you trig out the dimension of RU2
Hope this makes sence
Problem 2
There's loads of threads about rotating RU8 to suit disc brakes better but all the threads are old and the pictures are missing, can anyone help me out??
Old 17th November 2014, 09:47 PM
Hi,
I can't help for problem 1 as I haven't done my rear uprights myself but bought them from Talonmotorsport.
Regarding problem 2, the book, page 72, says how tu place RU8 according to disc or drum set-up.
However, Talonmotorsport's uprights are designed to fit both disc and drum set-ups, as you can see on the following pictures of my car.
2013-10-17_12-58-32 by Voucht71, on Flickr
2013-10-17_17-10-06 by Voucht71, on Flickr
2013-11-24_15-11-40 by Voucht71, on Flickr
For drum set-up, this design also allows you to use flexi brake lines going directly into the drum cylinder with a straight male fitting, and not the copper pipe thingy explained in the book.
Hope this will help
Are you going for rear disc or rear drum set-up?
Old 17th November 2014, 10:19 PM
Yeah im going disc, i think rotating like that also helps with disc handbrake cable from what i can work out
Does anyone have a picture of a rotated upright with a caliper fitted?
Old 18th November 2014, 10:28 PM
Well I've tacked them up like this, looks right to me, anyone else pass judgment?
Passenger side and drivers side
And the hubs will bolt on like so
Old 19th November 2014, 04:21 PM
You may want to go and get the whole caliper assembly and offer it up to the upright before you go any further, if you weld it fully and it's wrong it's a royal pain in the arse to fix.
Old 19th November 2014, 06:57 PM
Haha, i have done, are you saying they look wrong?
Old 19th November 2014, 07:54 PM
The book was wrong if I remember correctly with regard to drum and disc in the drawings.
You may find you cant get the caliper etc on as you have it when fitted to the suspension,as Phil said royal PITA to fettle.
The drum set up will fit with cylinder upright as it is fitted to all the Sierras that had drums on.
Old 2nd December 2014, 10:18 PM
Can anybody help on my first issue? It's as if the book contradicts itself
Old 13th January 2016, 05:20 PM
Ricky Ricky is offline
Hi has anyone figured the problem with that measurement on the upright that says 66 in the book but is showing 70 when you measure it has anyone perhaps know if 66 is wrong and 70 is right please? Thank you
Old 13th January 2016, 09:34 PM
mopple mopple is offline
Hi Ross,
According my CAD model the upper bone hole is 58 mm from the RU5 tube or jig surface and all other dimension match with book diagrams within a few tenths of a mm. Here's a screenshot https://onedrive.live.com/redir?resi...nt=photo%2cJPG.
Regards
Madis
