Old 19th November 2014, 09:29 PM
Default pre-IVA check-list
I think I remember there was a post about a pre-IVA check list somewhere on the forum, but can't find it in the sticky's. I'm not taking an IVA test, but my last inspection in Sweden on Friday, and I thought it could give me headlines to make sure I'm not forgetting anything before going.
Anyone can help please ?
Thanks.
Old 19th November 2014, 10:09 PM
rpjg1975 rpjg1975 is offline
Can't get the link to copy on my phone but if you do a search for 'checklist' there are 5 results. One of them is a thread by forum member spikehaus who did the blue v6 roadster which certainly contains some stuff about IVA stuff to check.
Hope that helps
Russ
Old 20th November 2014, 02:19 PM
Thank you Russ!
So, I think I'm ready
- oil level checked
- coolant level checked
- full fuel tank checked
- engine starts and run (!)
- tyre pressure checked
- mirrors checked
- clean the car, fuel tank and oil sump checked
- e-markings on lights checked : yesterday I spent hours removing my "mini style" rear lights, bought at CBS, E-marked, but without the correct numbers for whether they are blinkers, stop light or rear position light. So pissed ! I had to put 2 ugly trailer's back lights, with the right markings, as well as new side repeaters.
I also had to remove my 4 points Sabelt harnesses because 4 point isn't road legal apparently here, even though they are e-marked . Only 3 point seat belts are allowed. So I had to buy two new 3-points seat belts and fit them for the inspection...
IMG_1400 by Voucht71, on Flickr
IMG_1403 by Voucht71, on Flickr
I think I'm OK now. So, knowing that here we don't have radius requirements you have in the UK, do you guys see anything I should check before going?
Thank you
