Old 23rd January 2015, 08:02 PM
KenK KenK is offline
Default Hazard light help
I am using LED indicators. I have changed the relay to one for LED,s, the indicators work fine, flash ok etc however when I switch the hazards on the indicators all flash but instead of flashing on and off they flash on then dim i.e not fully off.
Using Sierra wiring and switches, anybody any ideas what's wrong please?
Thanks
Ken
Old 23rd January 2015, 08:26 PM
NeilW NeilW is offline
Not 100% sure! but i have seen threads previously about people having to play with various relay types and/or resistors.
Link http://www.advrider.com/forums/showthread.php?t=641854
Might help
Old 7th February 2015, 07:29 PM
Thanks Neil, had a look again today, after trying different relays etc I found that if I took the bulb out of the button the lights work ok. I have an Acewell dash which has the required warning lights so should be ok with that
