Old 31st July 2015, 12:09 PM
NeilW NeilW is offline
Default Engine details on V5
My original donor is currently declared as sorn, looking at the point system to retain original year of registration should I update my Sierra V5 with details of the zetec engine that I plan to use to help add up the points?
Has anyone done this before?
Total Spent so far - £xxxxx
Last Purchase - Engine mounts, steering wheel, slave cylinder.
Old 4th August 2015, 09:42 AM
IVA with original and notify change later,less hassle.
Old 4th August 2015, 09:28 PM
Thanks for the detail, I decided that I will just update the v5 with the new engine details. I called the dvla to explain that I need to update the v5 with details of an engine and gearbox change (as it's an auto donor). They said just to update section 7 with engine number and include a cover letter stating transmission changed to manual.
I can also provide evidence by way of either garage services invoice or independent inspection (the latter may be slightly difficult)
It takes approx 4 weeks.
Once all done I should receive an arp after IVA and I register with personalised plate at application.
Old 5th August 2015, 10:21 AM
They may want pictures at IVA and it has been posted on here before that it has been requested by some VOSA stations,just being totally correct in what they do.
Old 4th June 2017, 04:49 PM
nilocp nilocp is offline
I tried to change the engine from a 1300 to 1600 on my donor Escort V5.
They returned it and said NO, do it when the car is back on the road!! The car was on SoRN.
Colin
Old 5th June 2017, 07:12 AM
Cropper Cropper is offline
I changed an incorrect engine number whilst my donor was worn, it was never done properly when the car was imported, they had just used part of the chassis number. Just filled in V5 and sent it in, no issue
