Old 14th August 2015, 05:27 PM
silvertail silvertail is offline
Question SVA OK - brake master cylinder mod
Hi all,
Just revisited my Roadster project after a break, and I wanted to get people's opinions on a mod I made to my brake master cylinder.
The original problem was: the slots on my m/c were too far spaced out to meet with the holes on the pedal box plate (which had been positioned as per the book - it looks like my donor m/c was an unusual Sierra type - typical! ).
I extended the slots on the m/c to 'fix' this issue. Having done this mod, I'm now worried that the SVA tester might not like it, even though the original design had slots anyway - any opinions?
Original m/c:
Modified m/c with wider slots:
Modified m/c roughly in position:
Old 14th August 2015, 05:37 PM
With washers and nuts on there they wont see it anyway, but even then I don't think this will cause an issue as its not weakened it in any plane that would make a difference to braking.
Old 14th August 2015, 09:15 PM
SVA man won't give two hoot's ... He was replaced by IVA man years ago.
Old 17th August 2015, 09:31 AM
Cool thanks for the comments, and I should have remembered about IVA/SVA change - amazing they haven't changed it again already!
Old 17th August 2015, 10:54 AM
Cover your back and make some shaped plates and fit lock lock nuts and washers.
Old 18th August 2015, 10:47 PM
Badger Badger is offline
As above, I see no problem with that. Nylocks and plain washers would be the best for the job I'd say.
If dysfunction is a function, then I must be some kind of genius.
