Old 15th August 2015, 04:04 PM
Numplumb Numplumb is offline
Default Windscreen
Hi I'm looking for information on what size and where to get Ali for windscreen frame, what wipers and wiper motor to use etc.
Any info would be welcomed
Regards Mick.
Old 15th August 2015, 06:00 PM
garyt garyt is offline
hi Mick for what its worth, I used a wide body westfield screen and frame (reshaped on lower bottom corners), westfield wipers, and an mgb 1972 wiper motor, box, drive and wiper gearboxes. the drive part all comes to bits so you can shorten the tubes, to suit as required to the first wheel box , then the second and a short tail, the inner can be trimmed so that the end is enclosed once final length is known.
on the wheel boxes I reshaped the rubber bit inside and the chrome part outside as the angle was out for me.
as I was using an mx5 loom it plugged straight in and added an earth to the last connector and I had all functions as per mx5 ie, 2 speed, intermittent and wash wipe.
I also used a universal washer bottle with pump (available in heeps of sizes / shapes on the bay)
I have my wipers a little to close to the screen so had to adjust the arms a tad so they didn't bind at vertical
or if lucky you might get a complete westy wiper set up which should be pretty close
Regards Gary
Old 15th August 2015, 06:02 PM
there was another windscreen thread about 7 or 8 down in body work which had some more details / photos
Old 15th August 2015, 06:57 PM
Thanks for the reply, I've just read your post looks really good what you have done.
I will have to start looking now for the parts you mentioned.
Regards Mick.
Old 16th August 2015, 08:00 PM
swanntech swanntech is offline
Default wipers
if you want to make your own windscreen g b s sold me the ali u channel to make the frame .and old mini wipers can be made to fit
Old 17th August 2015, 11:17 AM
Pug and Citroen 107/c1-2 have a single wiper that may be able to be shortened to fit and would look good too.
Old 17th August 2015, 10:14 PM
Hi thanks for the reply
Can you give me a web address for them and what size channel you used please.
Regards Mick.
