Old 19th August 2015, 08:05 AM
Default LED rear lights
Right chaps I could do with a little help or advice. I'm no sparky so this might be easy for someone to answer. I went to fit my rear light's last night into my rear arches, and where they would be the wiring will be very close to the wheel (witch I don't like). So 2 option. 1 Modify my rear arches again to bring my current light out a bit to clear the wheel or slim LED lighting. So had a look around and found some nice rear LED light clusters. what is the story with needing to fit resisters to clusters? I have read that you need to fit a resistor to a single LED but I cant find anything on clusters so could someone help me out before I go buying some
