Old 1st September 2015, 01:39 PM
davepro62 davepro62 is offline
Default MX5 Diff Mount
Fitted the diff last night, is the 205 measurement correct, it looks to me like the drive shafts will be point forward.
I also note that the front of the diff is not central to the transmission tunnel, is this correct?
Thanks
Old 1st September 2015, 05:04 PM
RichardH RichardH is offline
what plans are you using? i am using a talon chassis kit and yes the drive flange is offset slightly and shafts point forward a bit. you need to take into account the sliding movement of the cv joints with suspension travel
Old 1st September 2015, 05:20 PM
Default MX5 Diff Mounts
Thanks Richard, I'm using the Saturn Plans so I know it's different.
Old 1st September 2015, 11:26 PM
On the Saturn plans the driveshafts do point forward a bit. Have a look through the various threads of completed cars as the diff nose mount on those plans isn't strong enough.
Old 3rd September 2015, 07:18 PM
I'll second that.
Having the diff mount fail and snap the diff in two isn't much fun!
