Old 23rd March 2016, 01:40 PM
SteveH1 SteveH1 is offline
Default Aluminium
Hi all
Just curious how many sheets of aluminium people used for their build
Thanks
Stephen
Old 23rd March 2016, 02:23 PM
1 8x4 sheet I used.
Old 23rd March 2016, 09:35 PM
Josh's Avatar
Josh Josh is offline
1 x 2m*1m 2mm sheet for the floor sections and fuel tank
3 x 2.5m*1.25m 1.2mm sheets for the sides, rear panel and all internal panels
All half-hard 1050
Josh
Old 23rd March 2016, 09:59 PM
I'm the same as josh and I still have a bit left and the of cuts have came in handy for making brackets. I bout all mine from aluminium warehouse and not to bad on the price
http://www.aluminiumwarehouse.co.uk
https://haynes.co.uk/forums/showthre...=13262&page=14
Old 24th March 2016, 08:29 AM
As above and from the same supplier, the sheet I ordered for the rear hub came damaged, sent them a photo of the damage and two days later there was a replacement sheet and kept the original damaged sheet, couldn't fault their service.
Old 30th March 2016, 07:44 PM
With ali sides, bonnet and rear tub, I used 3 sheets of 1mm and 1 sheet of 2 mm half-hard for the floor and tank.
Old 31st March 2016, 07:56 AM
Thanks all
