Hi all
I bought my rear arches 6 years ago, finally got round to fitting them (this project has been dragging a bit!) There are some large cracks, where I assume air bubbles have propagated? There are also various other hairline cracks. Can anyone suggest how I should go about fixing these? I also recently painted my first fibreglass panel - the scuttle. It wasn't until the primer went on that I noticed a small crack. I decided to press on with painting however because at this stage I'm not too bothered, I just want to car on the road! For future reference however, how should I go about fixing this? Thanks! Josh ![]() ![]() |
Would that have been saturn nts or Gillham that you got them off
The rear arch I would just dremel the damage out down to the glass and filler and paint or buy another pair The part with the stress cracks get yourself some matching gel coat Lightly sand the area with some 400grit Wipe the area with the wifes acetone for remOving her nail tips (I can give you a link to buy her more Dremel a very groove to open out the cracks down to the glass then mix up some gel and carefully spread into the cracks leaving slightly proud Cover with parcel tape (sticky side down) it's not a joke trust me it helps the gel harden up properly Remove tape and flatten back getting finer in grit till you get to 1200grit (I go to 2000grit) then Polish and buff the area to bring back the shine Or buy some more arches and panels off me lol Hope that helps Last edited by vmax1974 : 19th May 2016 at 01:44 AM. |
I think the ral number for that blue is 5005
They were from Triton, aka Fabbyglass I believe.
Thanks for your suggestions, I will give it a go and see how I get on. If all else fails, I may just buy a new pair from you...! Cheers Josh |
| Thread Tools | |
| Display Modes | |
