Old 14th January 2017, 02:54 PM
SteveH SteveH is offline
Default Mx5 harness woes
So in the last couple of days I've started to pick apart my harness
What a bleeder of a job this is
Anyone else pulled apart a mx5 harness?
Old 14th January 2017, 03:02 PM
Cropper Cropper is offline
Yes! Be patient, that's my best advice. Just for info if your donor was a mark one you can use the headlight lift power supply for your rear fog light as it only lifted the headlights for dip & main beam.
Old 14th January 2017, 03:16 PM
The donor was a mk1 import
And I've already pulled out the headlight retraction wires and some other circuits that are not needed
Old 14th January 2017, 05:29 PM
chris_smith chris_smith is offline
Funny you posted this today as it's what I've been doing all day...... how cold ....... and time consuming
Old 14th January 2017, 07:05 PM
For some reason on my loom I'm missing some labels of the connectors
I thought I labelled it all when I removed it from the car
So now I'm tracing wires back with the help of some dodgy wiring diagrams
Almost there though I think
