I have attached an image of my current light beam pattern. Failed the IVA because of the blur around the flick up.
MX5 loom, headlamps from CBS, replaced the bulbs. Any ideas what could be causing the blur?
One day it will be on the road...... |
Mm I'm not sure but are both light images the same n/ and o/s ? On projected image there are only 3 variables ,1 lenses or 2 bulbs or 3 reflectors
I ware the light units a pair ? As if there is a blur I would suspect the lens What size lights I have a spare 7" lens unit if required
remember we are not mad just creatively insane |
I have pretty much ripped the wiring appart and checked all earths to rule that out, changed the bulbs and now thinking lens as well.
Yes they are 7", if they will fit i will give them a try. Shall i pm you my address?
Yes pm me your address I have one spare unit that you are welcome to at least if that sorts the issue then your halfway there, will get it posted tommorow all being well
Message received will get it posted tommorow oh and I have ignored the other part of the message
Thank you, appreciated. I will let you know what difference it makes to the pattern once it is fitted.
posted this afternoon , hope it helps
I failed the IVA on the same thing, MX5 build with 5 3/4" headlights, all brand new. I was advised by the tester to get better bulbs, as they had seen this issue before, so i stumped up for the best bulbs i could & it passed OK second time. Just a note that the kick up they fail you on isn't tested on an normal mot!
Got the retest next Tuesday so im hoping changing the lens and new bulbs will do the trick.
Received it today, thank you Gary. Noticed it is the same make and model though as the ones i have..
Anyway, connected it and it made a massive difference. Before
| Thread Tools | |
| Display Modes | |
