Old 28th February 2017, 09:47 PM
Wain Wain is offline
After, big difference:
File Type: jpg Gary headlight garys bulb_crop_489x265.jpg (79.9 KB, 5 views)
One day it will be on the road......
Old 28th February 2017, 09:48 PM
Also tried swapping my bulb with your lens:
File Type: jpg Garys headlight my bulb_crop_489x299.jpg (90.9 KB, 3 views)
Old 28th February 2017, 09:50 PM
And put your bulb in my headlight:
File Type: jpg My Headlamp, Gary bulb_crop_449x231.jpg (62.4 KB, 1 views)
Old 28th February 2017, 09:56 PM
I think the last two pictures should be the over way round... Anyway, although your lens is same make and model as mine, it gives off a different pattern. Also noticed the bulb is same make as the lens. Guess i will need to get a new set of lenses, you agree?
Either that or i try and get through the IVA next week with one lens that gives off the correct pattern
Old 28th February 2017, 10:21 PM
garyt garyt is offline
Yes from those pictures definitely the lenses so have a look on eBay or try your local motor factors and see if they have another 1 , I take it both of your lights were throwing fuzzies?
Glad it helped and good luck on the retest
Old 1st March 2017, 12:57 PM
I cant believe what difference the lens has made, especially when they are the same make and model. Both headlights are showing the same fuzzy pattern. Do you want the spare lens back? if not, how much do you want for it?
Old 1st March 2017, 08:37 PM
Glad it helped pinpoint what was wrong no keep it and I don't need anything for it just if you can help a fellow builder along the way is payment enough
Now get that iva pass it will soon be Easter and nice driving weather
All the best Gary
Old 8th March 2017, 07:11 PM
Hey Gary, headlight patterns are now fine, thank you! Just a shame the petrol tank developed a leak and the handbrake isnt efficient enough to pass....
Old 8th March 2017, 10:09 PM
Hi Wain I'm in deepest darkest Kentucky at the moment
Fuel tank leak where's it leaking from ?
Hand brake , start on the rear adjusters you have to remove a bolt then adjust them , then move onto the cables just google mx5 handbrake adjustment and it's all there , I had some slippage on the cable where I had modified it but removed the plastic sleeping and redid it and it was fine
If the tank is leaking from a seam get a bar of soap and rub the seam the wax goes in and seals it temporarily but it might just get you through
Let me know how you get on with the brakes as once mine were adjusted they were solid and let me know about the tank leak and I will see what we can come up with
Gary
Old 8th March 2017, 10:25 PM
I fixed the fuel leak, the pipe from the fuel pump had a pin prick hole, tried welding it in place previously but created the hole (obvioulsy before filling it). Replaced the pipe which comes out of the tank and sealed it.
The brakes are the tricky ones, had a seperate thread and discussion on here previously. Got Wilwood calpers so in standard form with cables to a handbrake has 8% efficiency! Was advised to add a lever inbetween the brake cables and a cable from the handrake, this brought it up to 14%. This time i added a bigger lever to increase force but was to big and hit the prop shaft hence fail!
Thinking now to move the handbrake to the side so its not directly above the propshaft with the lever running next to the propshaft. Hopefully this will put the efficiency above 18%
Because it has been over 6 months since i initially applied for the IVA i need to apply for an IVA again online. Gives me time to get the handbrake sorted!
