Old 1st April 2017, 08:47 PM
garyout garyout is offline
Default Rad mount dimensions, scuttle
Good evening all
I want to mount my radiator tomorrow and was wondering if anyone could give me the distance and maximum height I can mount it, I will be using Vmax panels so need measurements to get it in the nose cone.
Also I'm after the position the front of the scuttle stops and how high so I can mount the steering column.
Ta Muchly
Old 2nd April 2017, 08:40 PM
Which Rad?
everyone has probably done it slightly different. bust be 4 years since mine was trail fitted.
Old 2nd April 2017, 09:21 PM
I should of mentioned that, I'm fitting a polo rad I have sort of used equinox measurements as a rough ish guide not sure on how different they are to the ones vmax sells.
Gary
