Hi all,
I've bought some Titon 4-point harnesses - the top mounts are simple enough, 10mm I/D tube welded through a crossbar on the roll hoop, but I'm not sure how to connect the lower mounts - similar tube through the box steel of the chassis, or tabs (of thick steel) welded to the frame? I've searched the forums with no luck, and the SVA book is pretty vague (either that or I'm not reading it right). Has anyone used 4-point harnesses before? Cheers, Kev. |
| Thread Tools | |
| Display Modes | |
