Old 2nd February 2018, 02:13 PM
Question Wishbone made of box section?
Hi, I have just noticed that Rally design do box section wishbones for the locost & they are really cheap. Is there any reason why I can't make one's from 20mm seamless box section with a 2mm wall ? I am mainly concerned about clearance issues as the area is a little bigger. Assembly should be easier as well. I hope !
Old 4th February 2018, 08:04 AM
Ricky Ricky is offline
Hi are you on the Facebook group if not you should join maybe you can get more answers there . But to answer your question I'm not entirely sure but think seamless tubing I think is a bit over kill cause here in south africa they race them and they use normal 1.6 mm round tube and they happy with it
Old 4th February 2018, 11:28 AM
Thanks for that, it's appreciated.
Old 4th February 2018, 11:58 AM
I have put a request up on the group now Thanks, I just need someone to accept my request if that's possible?
Old 4th February 2018, 12:45 PM
Ok it's the haynes roadster group I think just give it some time the admins will add you
Old 4th February 2018, 07:12 PM
Hi Jason,
Sorry but no, Rally design's wishbones are not made of box section tubes, but "Flat Oval Section" tubes, which is completely different.
DAR002prod by Sylvain ROIG, sur Flickr
ERW_Welded_FS_Oval by Sylvain ROIG, sur Flickr
A lot of wishbones are made of flat oval section tubes tubes, as they are more aerodynamic (I know, not a major issue for our seven-like car!), and also, look neater than round tubes.
Honestly, I have never seen box section wishbones, I'm not sure it exists, so perhaps there is a good reason for that. And, if it has any importance, it will not look good either (imho ).
And I as said above, seamless tubes might be a bit overkill, but I would use at least ERW steel tubes for my wishbones.
Hope this will help
Old 4th February 2018, 07:19 PM
Thank you Sylvian, that's spit on thankyou. I may try the oval tube to be a little different.
Old 4th February 2018, 07:23 PM
Thank Jason,
If I has to redo my wishbone (or build another Roadster ), flat oval section tubes would definitely be my choice too .
Old 4th February 2018, 08:07 PM
What is the size used on that over pipes is all the wishbones the same or what
Old 5th February 2018, 08:50 AM
I'm sorry Ricky, it should be my bad English, but I don't understand your last question. Could you please reformulate? (some comas and dots might help as well )
Thanks.
