Old 25th March 2018, 11:13 AM
will_08 will_08 is offline
Default Engine bonnet clearence
Morning all
Just got my bonnet and sat it on my chassis, I was expecting my carb to touch, but my oil filler cap is too!
Now I've looked at more finished Haynes, I've noticed there's not many people with air intakes coming through the bonnet. I was fully expecting to have a k&n popping through, I kind of like it.
Anyone else had this before? I have no air scoop don't know if that makes any odds.
Cheers Will
Old 26th March 2018, 07:41 AM
My CVH has a filter out the top. Although if the new VOSA regs come in the engine will have to be replaced with something else.
Old 26th March 2018, 02:22 PM
jps jps is offline
Are you using a Pinto? I am expecting to have use a different rocker cover where the oil filler neck has been relocated to the back and angled backwards...
I expect a lot of people are either using injection engines or have carbs/throttle bodies that come out of the block at 90 degrees and therefore the cut out for the air filter is only seen from one side...
Old 26th March 2018, 06:19 PM
yeah Pinto, thanks for the feedback.
like i say the air intake i was expecting, but not the filler cap!!
i'll keep playing and see how i go
Old 27th March 2018, 09:03 AM
jps jps is offline
Worth a look: http://www.locostbuilders.co.uk/view....php?tid=62500
Old 27th March 2018, 03:34 PM
Is it IVA checked already?
Old 27th March 2018, 11:10 PM
I like the golden rocker lid
No it's not Twin, I'm.on a serious go slow with my build. Want to make some proper head way this year!!
Old 28th March 2018, 07:39 AM
Are you aware of the impending possible IVA emissions change?
Old 28th March 2018, 09:22 AM
Ianr Ianr is offline
Oil filler cap is often cut off and relocated at the rear of the cover to make them fit under the bonnet on the Pinto engines
Old 28th March 2018, 09:54 PM
Twin in a nutshell I'm hoping to get finished next year, my 1600 pinto will have to pass the current emission standards? What's the prospect of that do you know?
