Good day
I've searched through past posts about this but I'm still after some help. Bare with all the questions!! Does any one know if the switch as fitted to my 1.6 pinto will be ok to control the fan on my rad. This is a switch with a green plastic top and single spade on it, right? Is the temp range suitable I mean? Also I was going to fit a tee in there for my water sender and dash gauge, should be ok shouldn't it? I was also going to tee into the oil pressure low switch for my pressure sender, that be ok? Cheers Last edited by will_08 : 25th August 2018 at 07:50 AM. |
| Thread Tools | |
| Display Modes | |
