Old 9th May 2009, 10:51 PM
7ishNZ 7ishNZ is offline
Default E36 diff and axles
Has anyone used the e36 diff and axles in the roadster? Did you have to shorten the axles, or did you change the rear track?
I have a 2006 R1 engine, so am after a diff ratio below 3.5. The bmw has a good range of ratios and LSD's available, but I am concerned about how heavy it is.
I am in NZ, so there are almost no sierra's left here, and the 3.14 and 3.38 ratios are like hen's teeth!
Any help would be appreciated.
Old 20th May 2009, 11:05 AM
Danny Danny is offline
I would be quite interested in what you find in NZ as well.
A quick look on trademe shows bugger all sierra parts,
i was thinking Nissan silvia rear end like the frasers use but the popularity of drifting has made them quite expensive.
I haven't looked at BMW parts yet as i always beleived them to be expensive but compared to some of the japanese rear ends they may be viable.
I will check back on this thread with interest
Old 22nd May 2009, 09:40 AM
I have gone with the nissan rear end. The silvia S13/14 diff has a 3.5 ratio as an option,wth 4.083, 4.1 and 4.3 commonly available. The lsd's cost about $100. There is also a number of different axle lengths....
A trip to the local BMW wrecker showed that there are very few different ratios available in NZ, and the lsd's go for about $1000!!! Nissan it is.....
