Old 18th July 2009, 06:08 PM
semtexsteve semtexsteve is offline
Default welding
hi i was wondering at what stage is it best to start to fully weld the chassis as i may need to move it soon and are there any tip as to were i should start and the best way around to go about it thanks
Old 18th July 2009, 07:18 PM
thwang thwang is offline
depends how far you are into the build if you have all the front end built i cannt see why you couldnt weld it up.have you welded the underside if yes weld it up opposite corners so you stager the welds.
thwang
