Old 26th August 2009, 06:01 PM
andyuk697 andyuk697 is offline
Default doner needed (yorkshire)
as title says really
ford sierra preff 2.0L type 9 etc etc
cheers Andy
Old 29th August 2009, 06:24 PM
if the sierra route fails whats the next low budget option of a doner
thanks Andy
Old 29th August 2009, 06:30 PM
It won't fail, there are still plenty out there. I would advise spending more if necessary and getting abetter one. By the time you've paid out for everything, a couple of hundred saved on a donor will seem quite irrelevant. Get a runner and drive it for a while, find out if everything is working well, replace anything that isn't. That will be a good starting position.
Next potential donor is the E36 3 series BMW, but obviously modifications to the Haynes design will need to be made, and special parts will be needed also.
Old 8th September 2009, 09:02 PM
the search still continues....
is there any model or year of sierra that cant be used? or
is there a prefered model or year to look for do i need to look for one with milleage under a certain amount for eg 200,000
if i do find one come up i dont want to jump on the wrong one lol
thanks Andy
Old 8th September 2009, 11:42 PM
davidimurray's Avatar
The 2L Pinto is quite a rare beast to track down. I'm using the 1.8 Pinto, although I would have also gone for a 1.8 CVH. Personally I'm not a big fan of the DOHC and MT75 box due to their size. My plan is to build the car and get it running with my 1.8 pinto, this also allows me to go for an age related plate. Then while hooning around in the car prep a C20xe to slide under the bonnet for a truly experience
Old 9th September 2009, 10:13 PM
aerosam's Avatar
aerosam aerosam is offline
How about buying any old sierra with a type 9 gearbox, and getting a 2.0 pinto elsewhere? Scrappie, ebay? Trawl the retro ford/capri/escort/sierra/granada forums and you should find a few good ones for sale.
Old 24th September 2009, 06:30 PM
can i use a 1991 f reg sierra or will it have wrong engine and box ?
what about a pinto with efi? can i use that engine
thanks Andy
Old 24th September 2009, 08:30 PM
richardk richardk is offline
What about this bad boy?http://retrorides.proboards.com/inde...y&thread=67902 go and get it , drive it back, if it makes it back to yorkshire its a good un !! Good price though.
Rich
Gallery updated 01/11/2010
http://www.kilmartin.it/cgi-bin/gallery
Old 24th September 2009, 08:57 PM
cool think its a bit further than i would like to travel tho
just missed out on one on ebay for £250 congrats if it was someone on here that won it
Andy
Old 25th September 2009, 08:00 AM
I wouldn't worry too much about the engine in the car, its not like you HAVE to use the engine. I'd concentrate on getting one with the right running gear and gearbox.
You can use any engine off the sierra and any gearbox. Its just that the pinto and a type 9 is the easiest to squeeze into a kitcar. In all honesty, the more you read about kitcars, you'll probably end up modifying your scope / design.
I decided to source my engine separately, because it will be a long wait for the perfect donor, plus I wanted a pre-cat engine as I think its easier to set up a carb engine than fuel injection / cat converter.
