rear suspension chassis plates
i have fully welded cp1,3,4,5,6 & 7 along with shock mounts and welded it to the frame work and have just noticed that itsnt stitting horrizontal and leaning downwards, i have also built the whole rear section of the car aswell. the question is will i be able to heat it up and move it upwards or do i have to cut it off the chassis and re do the chassis plate section again?
If your saying the whole rear chassis is on the skew.... you'll have to chop it out and do it again You'll be able to heat stuff up, but all your doing is curving tubes and plates, as the welded joint angle ain't going to change. So unless you want a car shaped like a banana
all the rear section sits horizontal except the suspension top mount plates? and the measurements are all correct give or take a 1mm
i think i will just cut the plate off the chassis and buy some new 1's. there's a place called www.oweneng.co.uk that sell them all ready put together and the plates are foldedinstead of welded any1 bought anything from there before??????
I got the diff mounts from them,no problems and good quality so no complaints and sent quickly.
nice 1, ive already ordered the plates so hopefully ill get them before the weekend.
Thread Tools | |
Display Modes | |
