Old 6th September 2009, 05:22 PM
aerosam's Avatar
aerosam aerosam is offline
Default What threads are the maxi balljoints?
I bought my maxi balljoints as part of a package from somebody on the anti Chris Gibbs forum and unfortunately I only received 1 nut. Now I have the car as a rolling chassis the bottom wishbone just falls out with no nut to hold it on.
So what is the thread, and does anyone possibly have a spare nut?
Thanks!
Sam
Old 8th September 2009, 12:03 PM
aerosam's Avatar
surely somebody must know?
Old 8th September 2009, 12:27 PM
Beardy_John Beardy_John is offline
I got mine from ebay, and they came with nuts. I'll measure them up tonight, unless someone beats me to it
www.beardyjohn.com Build blog and associated ramblings (Updated - 17/07/09)
Old 8th September 2009, 01:46 PM
Thanks!
Sam
Surely you have a caliper or steel rule and a thread guage. Most Tap & Die kits come with a thread guage. Having said that, mine is metric only.
Or just very gently try a few nuts on it to see if one fits.
I have a sneaky suspicion it might be imperial
Sean
Old 8th September 2009, 04:28 PM
I believe they are 7/16" UNF
Had a quick look but have every possible Nyloc nut other than that one
Old 8th September 2009, 05:45 PM
from memory i think they are to corse to be 7/16 but i could be wrong.
Old 8th September 2009, 07:23 PM
Question Maxi ball joint thread
Right this is the best I can do
I have two different brands of ball joint, One is made by Veco & the other is made by QH.
Both have the same thread.
I have just put my digital caliper on them. In metric the diameter of the treaded part is 11.9mm
Now here is the problem
Both the 20 TPI & 1.25 thread gauges fit the thread.
My Osborne cutting tool guide lists the following Two possible sizes.
M12 X 1.25 is a standard metric fine thread
7/16" X 20 TPI this is listed as a UNF thread size
Looking at my metric conversion chart, it is noted that the mertic range for 7/16" is 11.112 - 11.5mm
So given the outside diameter of the thread, it is probable that the thread is M12 X 1.25 ( Metric fine )
But I would not still rule out the 7/16" UNF in view of the possibility that this component could pre-date the metric era.
Please remember, This information taken from my tool guide & intended as a guide only
With a little luck, some of the more able engineers on the forum will have an exact answer.
Old 8th September 2009, 08:04 PM
aerosam's Avatar
thanks guys.
An M12 nut will grip the first thread only then not screw down any further.
I can see me having to go and buy another balljoint just for the nut
Old 8th September 2009, 08:24 PM
A standard M12 metric nut will not fit
If it is a 12mm thread it will be a M12 X 1.25 thread pitch.
Probably your best option would be to vist your local steel stockist or engineering fixing stockist ( Take the joint with you ).
Either should be able to give you an exact answer.
Both 7/16" UNF & M12 X 1.25 are available on ebay
Old 8th September 2009, 10:44 PM
just take it down the local fixings shop and get them to find a nut that fits it.
my local chap managed to get me m18 1.5 fine nyloc nuts. took him 2days to find them but those babys are like hens teeth
