Old 16th September 2009, 08:53 PM
chriseyj chriseyj is offline
Default Steering Column Extension
Hi the book says to use thick walled tube to extended the lower sierra steering link. I was just wondering if anyone had any sugestions for the diameter and guage tube they used. Is 3mm sufficient?
Old 16th September 2009, 08:59 PM
if i remember correctly, the tube i used was 25mm diameter & 3mm walled,
Old 16th September 2009, 09:42 PM
Thanks Andy, I meant to measure the lower link earlier and find its diameter but the sun went down. If I ever build anything again I'll wait till I have a garage, will try not to admit that to the wife.
3mm wall is what I was guessing at.
Thanks
Old 16th September 2009, 09:55 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
I used 19mm 1.6mm wall - still fine 10k later. There is very little load on the column, only as strong as the tyre grip on the road.
Old 16th September 2009, 10:35 PM
That seems scarily thin to me, especially as it is taking a torsional load.
Sean
Old 17th September 2009, 03:37 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Personally i would say that 19mm x 1.6mm was a bit on the trust in god side of things especially when the item you are extending is around the 16mm dia solid
Ray
Old 17th September 2009, 06:57 PM
squbti's Avatar
squbti squbti is offline
hmmm, isnt that part of the steering rod suppose to be colapsible? mine is going to(has to according to the law here in Sweden).
Old 17th September 2009, 08:17 PM
the collapsible part is in the upper section of the column between CP16 & the steering wheel, & also you have the coupling at the rack end & most folk have a coupling fitted just below CP16 so this all ensures that the steering column would deform in the event of a head on impact.
the extension part is purely just that "an extension".
not sure of the rules in Sweden tho
Old 17th September 2009, 08:38 PM
Land Locked's Avatar
Ray
What's the wall thickness of the average propshaft? From my long ago college days a thin wall tube under torsional load is not much weaker than a solid bar of the same material and outer diameter. If I recall correctly the OD is of greater importance than the wall thickness.
That said I am a firm believer in Victorian engineering and would probably use the thickest wall I could find!
Old 18th September 2009, 04:45 PM
RAYLEE29's Avatar
Im using a bit of 25mm od 3mm wall seamless for mine
but some people use 16 guage erw for front wishbones!
so its personal choice at the end of the day
stronger is safer
even formula 1 guys get it wrong sometimes (No names I dont want to get sued) but we all know
Ray
