Old 18th September 2009, 11:13 AM
axle's Avatar
axle axle is offline
Default windscreen & IVA
Hi All
Is the fitting of the windscreen by the method of the book IVA compliant, it looks like the radius test for the pillar would fail? Also can you go through IVA with no windscreen?
Regards Axle
Old 18th September 2009, 11:49 AM
Chris Gibbs's Avatar
Chris Gibbs Chris Gibbs is offline
I think that you'd need some edge trim on the front edge of the screen support,possibly rubber "U" section. The IVA requirements are essentially the same as the SVA in this area, If you don't fit a screen it's not tested and it saves you having to fit washers and wipers.
Chris
Old 6th October 2009, 02:32 PM
axle's Avatar
Thumbs up
cheers Chris
Regards Axle
