Old 28th September 2009, 11:54 AM
jasongray5's Avatar
Default Flexy brake pipes and rear drums ??
Whats everyone else done with the above?
I haven't bought any flexy hoses yet, but looking at it, clearance is going to be tight where is goes into the slave cylinder.
Has anyone got picture of what they did? or are doing?
Cheers Jas Gray
Old 28th September 2009, 12:41 PM
you need to do it like this
Old 28th September 2009, 02:28 PM
jasongray5's Avatar
Cheers Ash!
If I remember correctly, didnt you get those fittings from Rally Designs? If so, would you mind telling me what I will need and how many of each! as I want to try and sort out the brakes this week?
Cheers mate
Jas
Old 28th September 2009, 03:16 PM
8 m10 flexi brake pipe ends. http://www.rallydesign.co.uk/product...oducts_id=1520
8 bulk head lock nuts
3m braided tube
the lock nuts dont seem to be listed on the site and i cant remember which size braided tube you need. i will have a look on my invoice tonight for the part codes.
for the fixed lines you will need the following. you can get it all from cbs or most local motorfactors. i already had all the below so dont have part codes. i have plenty of male m10 ends left as i got a box of 50. if you want a few give me a shout.
roll of copper tube
11 normal m10 male ends
6 m10 female ends
2 m10 t pieces
1 m10 Brake pressure sensor
if you need any more info just ask
Old 28th September 2009, 03:35 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
hi, how come you need two tees is one for the brake pressure switch or is it something else?
Ray
Old 28th September 2009, 04:14 PM
jasongray5's Avatar
Ray
I think thats what its for Ray!
Old 28th September 2009, 05:14 PM
One "tee's " the rear brakes L/R .The other contains the switch.
Old 28th September 2009, 05:45 PM
one for the rear split to left and right and the other for the brake pressure switch.
you can get away with one t piece on the rear if you use a mechanical brake light switch on the brake pedal.
Old 28th September 2009, 08:57 PM
frankie boy's Avatar
Hi Ash
Nice pic. That all looks very tidy. Looking for would to seeing the finished build.
Frank
my Roadster
Old 28th September 2009, 09:03 PM
come to exeter show she will be in the main hall. should be finished minus painted side pannels and iva
im going to rent a trailer to take it down unless i can find someone willing to loan me one for a weekend. hopefully i can have a little testdrive round the show ground friday night
