Hi all,
Are engineering comps. available to support the design of : 1. Suspension arms. 2. Torsional rigidity and 3. The load carrying capacity of the frame? Thanks Lex, at philrobin@aapt.net.au |
Hi Lex,
Unfortunately the calculations are not my property, and so I can't supply them. The majority of the work was done using the ANSYS programme and you should be able to get what you need if you have the programme and the chassis dimensions or can get someone to do the calculations for you. Sorry I can't be more help cheers Chris ![]() |
| Thread Tools | |
| Display Modes | |
