Old 23rd October 2009, 11:58 AM
LeonN LeonN is offline
Default Prop hight
I asc this becaus I am youseing a BMW engion and diff and need to know haw to mount them all. The prop will be leavel with the car as will the engion be leavel with the car and the diff. So one size. That of the prop hight shuld allaw me to work out all 3 bracket pares. Diff, box and engion. Can anyone help?
Old 23rd October 2009, 04:19 PM
As you are using BMW parts Leon it may be easier to fit the lot in temporarily and see how it looks for height and fit etc a bit of trial and error.
One forum member has fitted beemer and there are pics on here somewhere.
Old 23rd October 2009, 04:32 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
I think Chris's brother in law did an extra wide car with bmw power and there is someone else too
Ray
Old 23rd October 2009, 05:19 PM
I intend to sort of dry fit the lot this weekend. I gess the only vital things are. That that all run in a line and the oriontation of the output shafts on the diff. Is this in the middle of the rear suspencion bushes, for the arms. As vuwed from the side?
Old 23rd October 2009, 05:46 PM
On my build I have a center line on the board,The diff pinion center is in line with it so everything else would be in line as well and this keeps the prop straight too.
Old 23rd October 2009, 05:54 PM
SAme plan with the centerline. It's is the hight that concurns me. Haw high must the output on the diff be? Allso haw fare forth or back is it. Think I asked the wrong question.
Old 23rd October 2009, 06:00 PM
I would have to measure it,but its not at home and is in the garage I work in.
Someone will know of the builder in Poland who has done it I am trying to find him and will post if I do.
Old 23rd October 2009, 06:20 PM
That's grate. Tar
Old 23rd October 2009, 10:57 PM
I think it was Longerr,they built a roadster with a 318 motor not sure if they used box and diff but they had plenty of pictures.
Good Luck.
Old 23rd October 2009, 11:09 PM
I think that yoused a custom prop to link a BMW box to siarra diff. Think.
