Old 19th November 2009, 12:35 PM
axle's Avatar
axle axle is offline
Red face Front upper suspention arms orientation
Hi
I know this was somewhere else in the Forum previously before it got hacked by the low life. Could some body please tell me which way they should be fitted.
a)Short arm to the front or back?
b)Threaded part facing up or down?
Regards Axle
Old 19th November 2009, 02:25 PM
Tilly819 Tilly819 is offline
Heya
Carnt remember which goes front long or short but they are mounted so the upper ball joint is angled upwards
Make sence?
Tilly
Old 19th November 2009, 02:49 PM
long arm of the upper wishbone goes to the front of the car.
Old 19th November 2009, 08:23 PM
axle's Avatar
Hi
I have just managed to look at the book again, yes the long arm goes to the front but the threaded part faces down the way. I hope I am right!
Regards Axle
Old 19th November 2009, 08:31 PM
Axle,
do you mean it goes down from the chassis towards the wheel direction?
Old 19th November 2009, 08:34 PM
sorry, i got that ar$e about face
the thread goes down from the wheel towards the chassis, with the long arm of the wishbone at the front.
well thats what mine do
Old 25th November 2009, 10:51 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
er no Axle they point upwards from the car up to the tyre ill find a pic or take one for you
Ray
Old 25th November 2009, 11:04 AM
axle's Avatar
Red face
Hi
Yes you are right Andy, my little brain worked it out, if you look at the book page 63 last sentence it tell you that the longer arm goes to the front. on this basis the threaded bit will be pointing upwards pointing towards the car.
Hope this helps!
Regards Axle
Old 25th November 2009, 11:18 AM
RAYLEE29's Avatar
NOOO see above
Ray
Old 25th November 2009, 12:07 PM
dogwood's Avatar
dogwood dogwood is offline
Like disss...
