Old 29th November 2009, 08:32 PM
Question Fuel filler confusion
As per title really !!
I have read & digested the current draft IVA regulations..........Well to the best of my ability, that is
The issue of the fuel filler location is still a little unclear
My fuel tank is nearing completion, my thoughts now turn to the location of the fuel filler point.
I understand the regs state that the filler point is not to be located within a passenger or luggage compartment.
What I ask of you good folks............. If the rear tub contains only the fuel tank & remains unlined as to prohibit the use of storage.
Will this constitute a luggage compartment !!??
Looking at the lo-cost option of the filler cap directly fitted to the top of the tank .
Having looked at the cost of external locking aerocaps & sockets ........... I feel quite weak at the knees
Old 30th November 2009, 06:08 PM
Good question Ronnie,if the space in the rear tub is open to the air it should not be classed as luggage space as its not capable of containing said luggage.
I have the same thought and considering fitting a screw on filler cap/neck inside what would normally be the boot.
Those Aero caps etc are silly money (but very pretty ).
Old 30th November 2009, 06:24 PM
Before I fully commit to the fuel filler I can give some thought to the following options.
Contact my local IVA inspecor for guidance, he did say not to hesitate to contact him during the build.
Bite the bullet and splash out on an aerocap, yes they do look the muts nuts
Go the lo-cost route & scavange some suitable parts from the breakers.
Thinking....Filler flap hiding a filler point, this could be made lockable with one of those small electric servos that so many filler flaps tend to have.
I am aware that if the filler cap is not lockable then it must be tethered
Old 30th November 2009, 06:29 PM
IVA man is the best option I think as he will be testing it,same scenario as MOT,tester's interpretation of the written word (been down this road have we not).
Old 30th November 2009, 06:32 PM
am i wrong in thinking that the filler cap "must" be tethered if not lockable with the ignition key? hmmmm.
i have an aero filler cap with a key but still intend to tether it, do i need to?
thanks
Old 30th November 2009, 06:35 PM
Stop you losing it !(and it is very nice too)
Old 1st December 2009, 12:32 AM
ronnie my filler cap is in the rear tub. its not a luggage space if it cant carry luggage. my rear tub lid is technically an inspection hatch for the diff and to fill with fuel thats it.
Old 1st December 2009, 07:20 PM
can you have a threaded filler outside i.e. fitted to the exterior like this one
http://www.demon-tweeks.co.uk/produc...&pcode=MOCCAP5
Old 1st December 2009, 07:49 PM
No reason not to, as long as it meets the SVA requirements, which, for that part are;
03A Fuel Tanks
16. The fuel filler cap must either be tethered to the vehicle or be of a lockable type where the key can only be removed when the cap is locked or an automatically opening and closing, non-removable fuel filler cap
And
16 Exterior Projections
2. All ‘hard’ parts contactable with a 100mm sphere, which form an external surface or protrude 5mm or more from the external surface must have a radius of curvature of at least 2.5mm
20. Handles, hinges, push buttons, and fuel tank filler caps must not protrude more than 50mm from the external surface if the component does not project beyond the extreme outer edge of the vehicle. This is reduced to 40mm in all other cases.
Hope that helps a bit, looks quite a nice cap, but as can be seen above, would need some method of tying it to the filler neck
Sean
Old 16th December 2009, 02:56 PM
axle's Avatar
axle axle is offline
Thumbs up
Hi
All well said Sean, my only concern is the sharp edges on the lid.
Regards Axle
