Old 6th December 2009, 04:46 PM
Default Fixing the nosecone
How on earth do you fix the nosecone to the chassis? Also, is it normal to have to cut the bottom down to make it fit? Mine sits 20mm forward because the bottom edge is too deep and strike the chassis rail in the middle.
Old 6th December 2009, 05:27 PM
i had to cut mine down on the bottom and your correct it lands bang in the middle of the bottom chassis rail.
i welded two little tabs on each side of the bottom chassis rail and put to m5 bolts through. then i used two bolts on the top of the chassis rail. so all together there are 4 bolts holding the thing on.
Old 6th December 2009, 08:10 PM
Originally Posted by AdrianH View Post
Perhaps I used force and ignorance, or a slightly taller flabby nose cone?
But I could get the front edge under the bottom rail, it is sort of shaped _.-----._ at the front, so fitted that tang under the edge then puled the cone unto the top rails and seems to work well.
Must remember one day to screw that bottom edge in place!
Adrian
This is how mine was done, it is an ultra tight fit to have the lower lip tucked under the bottom chassis rail, but it does go i found if i got the nose to a nice room temp it made it a little easier
Old 6th December 2009, 09:15 PM
fabbyglass
Well I would say check the height of the chassis then as the mould can't shrink 12mm for one customer and grow back for the next......
Old 6th December 2009, 09:51 PM
Oddly enough this was one of my first worries "Oh poop, I hope my chassis isn't wonky" after tacking I'd never rechecked the dimensions But its bang on (+/- 1mm). I pulled the bottom over the lower rail and eased the top edge on, but its just too tight, so much so that the corner developed a crack in the gelcoat, when stretched.
I think I'll do what Ash did and pop some bolts in. I was going to try to rivnut it but I'll try something different.
Old 7th December 2009, 08:06 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
I have some nice dzus fittings that im planning on using they have a nice radius are chrome and use a 4mm allen key was planning on two from below onto bracket on front lower chassis rail and one either side on to bracket on top rails.
still need to cut about my widened locost nose but its on the list of things to do somewhere in my head lol
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 7th December 2009, 08:51 AM
Janne E Janne E is offline
I did like Ash G...
Janne
Old 7th December 2009, 09:56 AM
mine would go under but i didnt like the idea of it being under stress all the time. my ff is dead on book dimensions
Old 7th December 2009, 10:06 AM
mine had a lip round the inside so i just put 4 rivnuts in the chassie, 2 in the top and 2 in the front. got it from gts and despite having the worst finish possible to get it fitted ok
Old 7th December 2009, 10:25 AM
dogwood's Avatar
dogwood dogwood is offline
My Fabby (Triton) nosecone fitted perfic..
Not under stress at all,
I got 2 tabs at the top and 2 on the bottom rail for fixing.
I said at the time I got it how amazed, shocked, gobsmacked.
I was as to how well it fitted strait out the box..
Mark said "Of course it does....It was made for the Haynes...
If you ain't using a Triton (AKA Saturn) one then I may be a different story
