Old 11th December 2009, 08:43 AM
Default Cheap Fuel Tank
My reputation of being a bargain finder has always been known
But just thought i,d share this with you all..............
I have just bought a steel fuel tank from "the bay", it is brand new old stock, made of steel, its not fully as per book dimensions but fits a treat into a standard rear chassis area, as it sits slightly higher than the diff cage but it is 4.5 gallons (approx 24ltrs), it has the fuel "in" pipe in a good position for attaching the fuel hose from either the top of the rear panel or the side of the rear tub & the fuel "out" point sits nicely at the base of the diff cage.
but the best bit of all is the price..............
£29.99 DELIVERED inc VAT
Old 11th December 2009, 09:09 AM
dogwood's Avatar
dogwood dogwood is offline
Hi Andy.
Got a link or an item number?
Old 11th December 2009, 09:16 AM
Originally Posted by dogwood View Post
Hi Andy.
sorry can,t do linky,s but here,s the item number 360197921656
the photo makes it look as if it sits high on the end of the tank,(need to turn your head to the side ) but the tank actually sits into the chassis area with the long part of the tank as its base....imagine looking at the chassis from the rear...... the fuel inlet pipe would sit on the right hand side just above the diff cage area.
Old 11th December 2009, 09:25 AM
dogwood's Avatar
http://cgi.ebay.co.uk/ws/eBayISAPI.d...fvi%3D1&_rdc=1
Looks good to me mate.
certainly cant beat that price...
Nice to see you are living up to your Rep....
Old 11th December 2009, 09:26 AM
cheers for adding the link David
its about time i learnt how to do that
Old 11th December 2009, 09:32 AM
dogwood's Avatar
Yes you should.....
Did it come with the sender as well????
Any chance of seeing it in place?
Defo interested in it at that price,
Save me the agro of making a new one..
Old 11th December 2009, 09:37 AM
Yes you should.....
yes it came with the sender , tho not sure if the sender is the correct "ohms" or whatever as not wired it in yet, but the sender is new too .
i,ll try & post a piccie of it in my car.
thats what i thought, saves time making one .
Old 11th December 2009, 09:47 AM
piccies
Old 11th December 2009, 09:59 AM
Just a note for any aussie builders out there the Holden Gemini fuel tank is a very good fit.
car is looking nice and dusty
