Old 24th December 2009, 06:45 AM
fabrun fabrun is offline
Default bonnet dimension
hello everyone
can someone give me this dimensions (can you tell where you buy your kit)
thanks
and merry christmas
Old 24th December 2009, 10:41 AM
LeonN LeonN is offline
Someone will come along with the dimencions you require I am shore.
The BMW engions are quite tall so I am resurving judgment on scuttle, nose and bonet hight untill engion is in.
Mabey we will need to redesign the intake manifold so it does not sit ontop of the rockercover to make it fit.
Do you intend modaling the engion?
Old 24th December 2009, 11:05 AM
The rear of the bonnet is 230 mm above the rails, see page 94.
Old 24th December 2009, 11:26 AM
Depends on scuttle and nose cone used as the heights will vary if they are placed direct to chassis and not on original design for metal scuttle.
Old 25th December 2009, 11:23 AM
thanks
i will modeling the engine( roughly just for volume and hole fixation ), don't know when!
missing the front and the length
Old 25th December 2009, 11:43 AM
Cool I will be exited to see a BMW block in cad. Even if it is not realy detaled.
Good work.
Old 3rd January 2010, 09:24 PM
Chris_ Chris_ is offline
Running ITB's will lower the height significantly. As it gets rid of the inlet manifold sitting on top of the engine.
Out of interest what engine are you using?
Chris
Old 4th January 2010, 03:38 AM
bmw 316i 1.6 e36 compact m43
