Old 28th December 2009, 01:03 AM
Default Tube ends
There are around 8-ish open tube ends on the book chassis. How do you deal with them? Leave them be? Weld them shut?
Old 28th December 2009, 08:45 AM
I am simple going to fill with a plastic box section end and glue it in after the chassis is powdercoated. They are about £1 on ebay.
Old 28th December 2009, 10:09 AM
DaddyA's Avatar
DaddyA DaddyA is offline
I just cut out some squares in steel and welded them in, bit of sanding and bob's ur uncle or not?
Daz...
Old 28th December 2009, 06:31 PM
LeonN LeonN is offline
i cut little metal squares and welded them on to. did not take long.
Old 28th December 2009, 07:09 PM
TSM Locost's Avatar
Default 25mm plastic plugs
If anybody is interested i can do 12 of 25 x 25mm black plastic knock in plugs for £3.50 inc postage.
Be Lucky, Mike.
