Old 31st December 2009, 05:44 PM
Jezzer99 Jezzer99 is offline
Default CVH mounting
Hi all,
I seem to remember that if you try to use the existing CVH engine mounts then the steering column will foul it? Can anyone remind me, I can't find it with a search so wondering if it was pre-forum "wipe"
Cheers,
Jeff
http://berkshire7.blogspot.com/
Old 31st December 2009, 06:30 PM
Hi Jeff,
you are correct in your thinking..... to a point
you can use the nearside original cvh engine mount but not the offside as it does indeed foul the steering column, so you,ll need to fabricate one.
I made mine from 10mm plate for the engine mount point, 2 sections of 25mm box tube welded together & a 5mm plate for the rubber base pointing point.
might be a pic in my "Big day" thread of the offside mount i made.
Old 31st December 2009, 10:15 PM
Thanks, Andy - I knew I wasn't going barking mad... guess I better sort the column out and then finalise the engine/gearbox mounts from there.
Cheers,
Jeff
Old 1st January 2010, 11:51 AM
thats the order that i did mine too Jeff, once the column is in you can then see what space you have to work within.
have fun
Old 4th January 2010, 12:56 PM
NEroadster NEroadster is offline
Jeff,
I fabricated both sides in the end as I was unhappy where the engine mount was placed relative to the chassis rails. I fabricated the column side after I had installed the column and finished the mount on the other side
Old 4th January 2010, 01:15 PM
I believe that for what it takes to remake both engine brackets i would certainly recommend it. So far i have seen two sierra engine mounts split at the rubber joint due to perished rubber. Land Rover engine mounts are cheap and stiffer and do the job very well, sierra mounts are very expensive to replace.
AndrewH
Old 4th January 2010, 09:41 PM
Thanks, guys - I think I'll fabricate new mounts for both sides. For the engine mounts, are you using Land Rover V8 ones like these:
http://cgi.ebay.co.uk/Land-Rover-Ran...em3ef686c64 b
Cheers,
Jeff
Old 4th January 2010, 09:48 PM
Hi Jeff....
yes thats the rubber mounts that i,m using, nice n sturdy
Old 4th January 2010, 10:28 PM
Me too Jeff
A fair bit firmer than the ford ones
Suit my Zetec engine a treat
Old 6th January 2010, 04:49 PM
GraemeWebb's Avatar
Ive just ordered a pair of these engine mountains but does anyone have the dimmensions, ie height and diameter so I make a pair of dummy units and can crack on with engine mounting before they arrive.
