Old 9th January 2010, 05:21 PM
happyjo happyjo is offline
Question 25mm tubing for front lower wishbone
Does anybody know where I can source the tubing for the front lower wishbones?
Preferably South east
25mm OD Seamless tube.
I can find the Plate £10 pair plus £5 P&p Ebay
33.7 x 2.6 tube £1.50 Ea Rogue Engineering
Suspension bracket £1.25 Ea Ebay
Just need to source the tube.
Old 9th January 2010, 05:33 PM
dogwood's Avatar
dogwood dogwood is offline
I got my seemless tubing from there people.
http://www.hublebas.co.uk/index.htm
got a depot in London
David.
Old 9th January 2010, 05:45 PM
Cheers Dogwood,
Do you know which one to pick, it has far too many abbreviations
CFS CEW CHB etc.
Does anybody know what these mean, the book does not state other than seamless.
Old 9th January 2010, 05:52 PM
dogwood's Avatar
Hmmmm, Good question.
I'm afraid I don't know the answer, sorry.
I just phoned them and told them what I wanted and what I was doing.
It was over a year ago so can't remember the answer.
Did find them very helpfull though.
David.
Old 9th January 2010, 05:55 PM
dogwood's Avatar
Just had a look on their site.
If you click "Full Range" it takes you into a page that details the tubes.
It looks like you want CFS cold drawn seamless.
HTH David
David.
Old 10th January 2010, 09:09 AM
Spikehaus on the forum had some one Evil bay (I think).
Old 10th January 2010, 10:12 AM
dogwood's Avatar
He has...
http://cgi.ebay.co.uk/Haynes-Roadste...item33586fc002
David.
Old 10th January 2010, 11:15 AM
Cheers Guys that's the 20mm, The drawing shows 25mm for front lower wishbones.
Can it be reduced to 20mm or would it be too weak?
Old 10th January 2010, 11:17 AM
Sorry to put a damper on that but I'm sure 'happyjo' was asking for front lower wishbone tubing which last time I checked was 25mm or 1" OD and that is 20mm OD might it not be alittle tight for the wishbone plate from Mr. Oxley Rogue Eng. on ebay? Happyjo if you want the correct tubing for the wishbones PM me and I will sort you a price for either just tube supply or fully profile cut tubes on the lathe.
Old 10th January 2010, 05:12 PM
dogwood's Avatar
Sorry to put a damper on that but I'm sure 'happyjo' was asking for front lower wishbone tubing which last time I checked was 25mm or 1" OD .
You're not wrong, he was. Sorry got myself all exited.
Then I'll go back to my original suggestion.
david
David.
