![]() Hi
I have a question for Chris, and anyone that wants to answer. I have just realized the chassis plates CP10 ( diff mounting bracket, plate)should be made out of 5mm plate. I have made mine from 3mm ![]() My question is this: Do I leave them as they are or cut them out and replace with 5mm I could double up the 3mm plate but would only be welded on one side. I do have an extra bracket on RS6 holding the back of the diff. So would help holding the diff in place. ![]()
. . David. Heaven, Warm days and Cool rides ![]() |
![]() Its a very good thing you mentioned that...i was making mine out of 3mm plate. Luckily they havent been finished yet
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
![]() nope you will need to chop it out and put a 5mm one in. there is a lot of strain going through that plate so don't even risk it.
that 2.0 is going to kick out quite a bit more power Last edited by AshG : 18th January 2010 at 06:16 PM. |
![]() Hi David,
sorry if its not what you want to hear but i,d agree with Ash on this one, even with your back attachment, for peace of mind change it to 5mm, you,ll always be worrying about it when driving ![]() cheers andy |
![]() Here's a picture of a Caterham chassis, showing what forces are at work in this area.
![]() Kind regards John
Quality parts for the Haynes Roadster - manufactured to a standard, not down to a price. Contact us at component-sales@hotmail.co.uk or visit our website www.3gecomponents.com
![]() Double up on the 3mm and plug weld through some holes drilled in it.
Rightly or wrongly I used 25x50 box with tube through one side so as it would not collapse and my diff brackets are the folded type. |
![]() Is anyone other than Dogwood doing the rear support for the diff? I was planning to as it just seems to make sense to have a rear support in it as originally design.
![]() I think i will be, can't cause any harm in doing so and it will give me a bit more piece of mind.
![]() Jeff,
i was "thinking" about doing it, tho to be totally honest i,m not sure, would be nice to have other,s points of view. i suppose there is also no reason "not" to do it, as its quite easy to do & doesn,t seem to get in the way of anything else. hmmmm also after seeing the pic showing a westie,s diff area damage i,m now thinking "Andy just bl@@dy do it" ![]() cheers andy |
![]() Hmmm... it makes sense the more I think of it; it's one less twisting force on the diff so I think I'm going to do it
Thread Tools | |
Display Modes | |
