Old 22nd January 2010, 08:00 AM
Default Problems fitting 2.9 quick rack?
I tried fitting my 2.9 quick rack from Rally Designs last night. On the thinner passenger side mounting, I fit the thick plastic spacer, but when bolted down it was still loose, and there was no room to fit the thin spacer under the wider drivers side mounting. Am I doing omething wrong, or has anyone else had this problem?
Adrian
Old 22nd January 2010, 08:31 AM
dogwood's Avatar
dogwood dogwood is offline
I assume you are talking about alloy brackets?
If so then it sounds like you have the spacers the right way round.
They deff should not be loose. Mine fit fine.
David.
