Old 15th February 2010, 09:56 PM
Davey's Avatar
Davey Davey is offline
Default 1.6 ZETEC blakc top free to good home
Well as it says in the title really. Bit of back story to it though, my son's 1.6 Zetec black top Focus chucked its cam belt and wrapped up eight exhaust valves punching one clean through No 3 piston. I got hold of a second hand 1.6 silver top and rebuilt one reasonable engine out of the two. What I have left is a complete (albeit in pieces) but bolox'd 1.6 Zetec black top. What it needs:
Crank regrind
One new rod
New big end shells
Rebore
Four new pistons
Eight new exhaust valves
Valve clearances sorting to suit new valves
Oil pump
Full gasket set
What there is:
Cylinder head with eight broken exhaust valves and complete with black top cover, buckets, cams etc.
Block
set of pistons and rods, one rod is FUBAR, pistons will need replacing to suit rebore
Main bearing ladder
Set of new std main bearings (crank should only need the big ends regrinding)
Sump
Inlet manifold
Throttle body
Flywheel
Front pulley
Oil pump (suspect)
Belt cover
The whole lot is free to a good home, if anyone wants any of the bits that's fine I can skip what is of no use to anyone.
For anyone thinking of rebuilding this motor I priced up the parts and machining and it came to around £700 so you have been warned. I just have no use for it and its taking up space, if no-one wants any of it I'll skip it.
D.
Old 16th February 2010, 07:13 PM
Davey's Avatar
I take it none of the bits are any use to anyone then. just thought I'd offer it up on here before chucking it in the scrap bin.
D.
