Old 19th February 2010, 07:14 PM
Default IVA results
what a long day.
She failed but the day was very positive and very friendly. there wasn't really any bad items so should only take a day or two to rectify. Andy the tester was a good laugh but went to the book by the letter which i must applaud. he knew what he was doing inside out and offered some really good advice.
here are the fail points
1.) Noise was 106db at 3700rpm
2.) i need a convex glass in the passenger mirror as the tester had to move his head too much to get the full range of view in that mirror
3.) my t pieces for the brake system were bolted to the chassis using riv nuts. this was deemed unacceptable as there is no locking device. i was advised to drill straight through the tube and use a bolt and nyloc nut on the end. all fixings/items on brake related systems must have a licking device!
4.) my roll bar back stays only had one bolt securing them. they either needed to be welded or have a minimum of two bolts.
5.) heat shrink and glued on rubber is deemed unacceptable for iva. any covering used must be equivalent to something a mass manufacturer would use. this meant i had to remove the heat shrink off the track rod ends which then failed (it was suggested that i used a caterham type item to cover these.)
6.) my universal joint on the steering was too close to the bulk head bearing meaning the collapsible mechanism wouldn't work adequately in an accident.
7.) speedo was out but was aloud to alter it at the time so it is now spot on.
8.) headlights were out but dogwood was aloud to align them for me whilst i sat in the car.
9.) side indicators failed. not because of their position it was because they were actually side markers which had the wrong e mark. the emark they had were for side markers not side indicators. the difference is that side markers have a lot narrower range of visibility than side indicators. you could see them from the back but the light emitted was not strong enough in the required direction.
think that was about it
good news bits
the shocks passed fine even without the rubber boots.
brakes were spot on
self centring was perfect (andy the tester commented that it was very very good for a 7!)
car weighed in at 620kg with full 25l tank and 115kg driver. take driver and fuel off and that's 480kg
emissions were fantastic infact miles under the limit.
Over the course of the day andy gave me lots of fantastic advice on passing the iva. i will do a full write up of all the tips in ckc. it was obvious he was really into his cars and really knew his stuff. all the points he made were fair and well deserved.
it was a good day out very educational and the car was bloody amazing beyond belief to drive. the whole journey there and back the car was totally spot on and didnt miss a single beat
and last of all i must say a really really really big thank you to dave (dogwood) he has slogged his guts out all week helping me and i must say i really couldn't have done it without him and my fail list would have been double the length. he certainly wont be buying any beers or food at stoneleigh this year!!
Old 19th February 2010, 07:24 PM
dogwood's Avatar
dogwood dogwood is offline
Gosh Ash, you made me blush..
But you are more than welcolme. after all that's what mates are for.
Mind you could have done without the 6am alarm call..
David.
Old 19th February 2010, 07:30 PM
gingea1pom's Avatar
Ash,
In a funny sort of way nice one, if you know what I mean.
Is there a book distance for Item 6, only I am about to cut my column to make the extention.
When is the re-test?
It has been like loads of expectant fathers on here today!
Cheers Ginge
Build Pictures
Old 19th February 2010, 07:49 PM
I expect you are feeling a little dissapointed Ash but not a bad result there
Like you say, it'll not take you long to sort those few things out.
Guess that's the touble with the new IVA .... Still a bit of an unknown quantity for many of us .... The new regs are well documented but the way they are being applied has yet to fully surface.
Got to say, well done mate
What a long day, bet you & David are knackered
Old 19th February 2010, 08:14 PM
Furry Muff
Let us know what u fit
To Quote a meerkat, "SIMPLES"
Elaborate, is the book design out of spec now.
Oooohhh... Hmmm.. Let us know the fix!!
Aaaarg... is this likly to be a problem for all of us?
BING
Bong
9.) side indicators failed. not because of their position it was because they had the wrong e mark. the emark they had were for side markers not side indicators. the difference is that side markers have a lot narrower range of visibility than side indicators. you could see them from the back but the light emitted was not strong enough in the required direction.
BASH
Can you take a pick for us of this
Old 19th February 2010, 08:15 PM
dogwood's Avatar
I'm sure Ash is feeling a little dispondent as well, but he really shouldn't.
The examiner commented more than once on the quality of his welding and build.
I think Ash should be proud (And I'm sure he is) of the way his car turned out.
The only real fail was the noise, which we couldn't try before the test.
The rest would have been almost a fix on the day.
David.
Old 19th February 2010, 08:24 PM
I agree with that David
Ash should be really proud of the Roadster that he has produced ..... It is a stunning example
If I can't have a first time pass, i'll take that list any day of the week
Old 19th February 2010, 08:48 PM
It's shorter than the fail sheet from my Mondeo's MOT last month
Old 19th February 2010, 09:12 PM
not really feeling down. i went in expecting to come away with a list of bits to do.
im just glad that i didnt fail on brakes emissions or self centering as they are all buggars to get correct with out the correct equipment
lets just say i now understand why the iva is more expensive than sva as it takes double the time to go over the car.
Old 19th February 2010, 09:14 PM
Ash,
A HUGE well done mate, that is one good fail list , it sounds odd to say that but honestly mate you should give yourself & Dogwood a huge pat on the back.
Thanks for sharing the points of the fail, as it will help us all i,m sure, as there are a few points that we would all get caught out with ( brake T piece / steering column ).
again ... well done to you both .( You & David)
